跳转到主内容
Smartab STJR700 Screen/Digitizer Replacement
你所需要的
  1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: 步骤 1 中的图像 1,2 Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: 步骤 1 中的图像 2,2
    • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
  2. Smartab STJR700 Screen/Digitizer Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
    • the front panel should now be exposing the digitizer along with the other electronic components of the device.
  3. Smartab STJR700 Screen/Digitizer Replacement: 步骤 3 中的图像 1,2 Smartab STJR700 Screen/Digitizer Replacement: 步骤 3 中的图像 2,2
    • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
    • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
    • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
结论
另外一个人完成了本指南。
Tianna Edwards
于03/22/17注册
128 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,131
