跳转到主内容
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
你所需要的
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: 步骤 1 中的图像 1,2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: 步骤 1 中的图像 2,2
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: 步骤 2 中的图像 1,2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: 步骤 2 中的图像 2,2
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: 步骤 3 中的图像 1,1
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
终点
另外一个人完成了本指南。
brittany
于07/16/12注册
234 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 555
