本指南有最近更改,您可查看未经巡查的最新版本。
简介
Sometimes the trigger on the Ion needs replacement due to wear and tear. While working on the Ion, the user should be aware of the pressure due to air inside the gun. Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels and cause embolisms. To avoid this, make sure to point the gun in a safe direction when de-gasing the Ion.
你所需要的
Turn the gun on by pressing the power button until the red light blinks.
Turn vision mode off by pressing the power button again.
Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
Remove the trigger pin by tapping it out of the right side of the gun using a 3mm screwdriver.
另外一个人完成了本指南。
