本指南有最近更改,您可查看未经巡查的最新版本。
简介
If the Ion is not shooting properly, the bolt's o-rings may need to be lubricated, or the bolt may be damaged from wear and tear. While working on the Ion, the user should be aware of the pressure due to air inside the gun. Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels and cause embolisms. To avoid this, make sure to point the gun in a safe direction when de-gasing the Ion.
你所需要的
Turn the gun on by pressing the power button until the red light blinks.
Turn vision mode off by pressing the power button again.
Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
3等其他人完成本指南。
