键盘底部印有所有的产品信息:法规表示,生产国家,以及全新的产品型号 A1636.
键盘为多片折叠设计,可以说是最令人困惑的折叠方式。
或许 Apple 也认为这种折叠设计会让很多人无从下手,所以在使用说明中印上了正确的折叠方式。
参照使用说明中的图解,终于搞清楚了如何正确合上这款键盘/保护盖。盖子几乎是平整的,键盘部分凸起(每个按键有 4mm 的键程)。三片式设计看上去和拆解后的 iPad Pro 内部结构十分类似。
该拆解下面的一层了。这一层也就是前面遇到的塑料盖板。它被大量粘胶固定,拆解时也需要使用大力.....将其折成两段。
此时,真正的键盘就显露出来——一层电路板,上面有按键结构和芯片。
STMicroelectronics STM32F103VB 72 MHz 32-bit RISC ARM Cortex-M3
Macronix MX25L4006EZUI-12G 4 Mb 闪存
由衷感谢以下译者:
100%
Ennis正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
34指南评论
I'm not either. I think that's going to be the norm (if not already) as devices become smaller and more complex. Not only from just Apple. I think the need to repair rather than replace will get less and less. I think this is a good thing, but it means scores like 'reparability' when reviewing or tearing down will continue to mean less and less to consumers over time. For myself, I already think it's a pretty glorified/meaningless statistic when reviewing a product I'm going to buy. As long as it's quality, and/or the manufacturer has a good warranty program, it's much more convenient for me to go that route. I can't remember the last time I needed to fix or pay to get fixed one of my electronic devices who isn't the manufacturer.
well, at some point of time maybe even you will grow up, take responsibility and try not to waste our beautiful planet with one-time, throw-away products..
i suppose most products of companies have a limited warranty of, let's say, 2-3 years maximum.
what happens if after the warranty ends and the keyboard fails to work?
since you can't repair it your self, you can only use it as a placemat for your dinner.
alexios -
Guido, there's this thing called recycling, perhaps you've heard of it?
rpe33 -
