跳转到主内容
加入维修社区 - 创建账户
Small Engine Recoil Starter Replacement
你所需要的
  1. Small Engine Recoil Starter Replacement, Recoil Starter: 步骤 1 中的图像 1,1
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: 步骤 2 中的图像 1,1
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: 步骤 4 中的图像 1,1
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: 步骤 5 中的图像 1,1
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: 步骤 6 中的图像 1,1
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: 步骤 7 中的图像 1,1
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: 步骤 8 中的图像 1,1
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
结论
5等其他人完成本指南。
James Marmaud
于03/20/17注册
276 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 15
总计 3,227
