跳转到主内容
简介
The purpose of this guide is to show the steps necessary to remove the casing of the Slingbox and replace the motherboard.
  1. Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. The Slingbox has four black 5mm screws, one on each corner of the case. Remove the four black 5mm screws using the PH1 screwdriver. Gently pull and separate the two case covers.
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox. Remove the five silver screws on the motherboard using the PH1 screwdriver. Gently slide and separate the motherboard from the base.
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
结论
Nitin Muralidhar
于2016年07月18日注册
222 信誉积分
创作了2篇指南
团队
IUPUI, Team 2-2, Harley SU 2016 IUPUI, Team 2-2, Harley SU 2016 的会员
IUPUI-HARLEY-SU16S2G2
5 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 449
