当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The Slingbox has four black 5mm screws, one on each corner of the case.
Remove the four black 5mm screws using the PH1 screwdriver.
Gently pull and separate the two case covers.
The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
Remove the five silver screws on the motherboard using the PH1 screwdriver.
Gently slide and separate the motherboard from the base.
Do not touch the heated tip of the soldering iron.
Check this guide out to learn how to use a soldering iron.
Desolder all three lead prongs.
Gently pull the DC power connector from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
