跳转到主内容
简介
The purpose of this guide is to show the steps necessary to replace the faulty DC power connector.
  1. Slingbox SOLO DC Power Connector Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO DC Power Connector Replacement: 步骤 2 中的图像 1,3 Slingbox SOLO DC Power Connector Replacement: 步骤 2 中的图像 2,3 Slingbox SOLO DC Power Connector Replacement: 步骤 2 中的图像 3,3
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO DC Power Connector Replacement: 步骤 3 中的图像 1,3 Slingbox SOLO DC Power Connector Replacement: 步骤 3 中的图像 2,3 Slingbox SOLO DC Power Connector Replacement: 步骤 3 中的图像 3,3
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  4. Slingbox SOLO DC Power Connector Replacement, DC Power Connector: 步骤 4 中的图像 1,1
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
结论
To reassemble your device, follow the instructions in reverse order.
Nitin Muralidhar
于2016年07月18日注册
222 声望
创作了2篇指南
团队
IUPUI, Team 2-2, Harley SU 2016 IUPUI, Team 2-2, Harley SU 2016 的会员
IUPUI-HARLEY-SU16S2G2
5 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 247
