跳转到主内容
Slingbox 500 Motherboard Replacement
你所需要的
  1. Slingbox 500 Motherboard Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Remove the sticker on the back of the Slingbox that covers the rear screws using a spudger.
  2. Slingbox 500 Motherboard Replacement: 步骤 2 中的图像 1,2 Slingbox 500 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 7.9 mm rear screws from the device using a Phillips #1 screwdriver.
    • Flip your Slingbox so the bottom is facing upwards.
    • Remove the four 7.9 mm screws using a Phillips #1 screwdriver.
    • You may have rubber feet on the bottom of your Slingbox. If you do, just gently remove them with your hands and set them aside to put back on later.
  3. Slingbox 500 Motherboard Replacement: 步骤 3 中的图像 1,3 Slingbox 500 Motherboard Replacement: 步骤 3 中的图像 2,3 Slingbox 500 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the upper section of the case by rotating your Slingbox to view the back and lifting up on the higher corner.
    • Use the opening tool to disconnect the small clips in the front.
    • These may require some minor force to disconnect.
    • Remove the entire top of the Slingbox and set it aside.
  4. Slingbox 500 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Slingbox 500 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove five 9.5 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Push down firmly on the screws as to not strip them when removing them as they may not spin easily at first.
    • After removing the screws the two metal tabs on either side will be free. Make sure to not bend them or accidentally damage the wires while doing further dissasembly.
  5. Slingbox 500 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the motherboard from the lower case.
结论
David Sullivan
于10/18/21注册
365 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-3, Simcock Fall 2021 UMass Dartmouth, Team 1-3, Simcock Fall 2021 的会员
UMASSD-SIMCOCK-F21S1G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 158
