跳转到主内容
Sliding Folding Door Hinge Replacement
你所需要的
  1. Sliding Folding Door Hinge Replacement, Hinge: 步骤 1 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove any remaining old screws and hinges that you want to replace.
    • Counterclockwise will remove the screws.
  2. Sliding Folding Door Hinge Replacement: 步骤 2 中的图像 1,1
    • Screws come loose when the holes become too large for the screws. If necessary, drill new holes into the door.
    • In this case, the top two holes were no longer usable, so we created more underneath the bottom holes.
  3. Sliding Folding Door Hinge Replacement: 步骤 3 中的图像 1,2 Sliding Folding Door Hinge Replacement: 步骤 3 中的图像 2,2
    • One by one, use the screwdriver to place the new screws.
    • The screws shouldn't be too tight. Be sure that the hinge is loose enough to rotate while placing the other screws.
    • Tighten all screws best you can with the hand held screwdriver.
  4. Sliding Folding Door Hinge Replacement: 步骤 4 中的图像 1,1
    • The new hinge and screws should be in place now. If you would like, you can patch up the old holes and paint over them.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 724
