跳转到主内容
Skytex SP728 Speakers Replacement
你所需要的
  1. Skytex SP728 Speakers Replacement, Case: 步骤 1 中的图像 1,1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: 步骤 2 中的图像 1,1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: 步骤 4 中的图像 1,1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: 步骤 7 中的图像 1,1
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
结论
另外一个人完成了本指南。
Chris Nelson
于01/21/15注册
213 声望
创作了2篇指南
团队
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 的会员
USFT-BROWN-W15S5G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 104
