跳转到主内容
Sky Viper v950HD Motor Replacement with Quick Connect Motor
你所需要的
  1. Sky Viper v950HD Motor Replacement with Quick Connect Motor, Motor: 步骤 1 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor, Motor: 步骤 1 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor, Motor: 步骤 1 中的图像 3,3
    • First you will need a Phillips PH0 screwdriver, shrink tubing that fits the thin wire, heat gun or lighter, Female Mini JST plug, and new or harvested motor (WLToys V949 motors work well).
    Where do I get a motor for my quad copter that is the Sky Viper v950HD in hopes of fixing the 2 stuck propellers?
    DHS RIDER - 回复
    Any place including Amazon or Ebay that sells the WLToys V949 motors. They are a perfect fit when fully seated and have metal cogs instead on plastic ones but they need to be fully seated .
    Miguel Rodriguez - 回复
  2. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 2 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 2 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 2 中的图像 3,3
    • Flip the Viper over. My Viper does not have a camera because it is damaged so remember to remove it.
    • Remove the 9 screws holding the bottom plate/battery holder.
    • Remove one last screw in the battery compartment.
  3. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 3 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 3 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 3 中的图像 3,3
    • Slowly pull the bottom off.
    • It should come completely off with little effort.
    • Then remove the screw holding the arm cover/led holder.
  4. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 4 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 4 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 4 中的图像 3,3
    • Remove the prop and the spacer.
    • Rotate the gear until you see the two screws as pictured and unscrew them. They may not come out of the gear easily so be careful not to lose them.
  5. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 5 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 5 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 5 中的图像 3,3
    • Slowly pull out the gear and motor assembly.
    • Carefully push the motor out of the gear side.
    • Once it is out you can inspect the gears and remove the small gear from the motor just in case it can be used later.
  6. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 6 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 6 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 6 中的图像 3,3
    • The new gear from the WLToys V949 should already have a metal gear that will match up the current pinion.
    • Press it firmly in place and connect the mini JST plug.
  7. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 7 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 7 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 7 中的图像 3,3
    • Put the entire assembly back and put the screws back in place.
    • Cut the wires at an offset and strip all the wires.
    • Place a small 14mm piece of heat shrink tubing on the wire, match black to black and red to red in this case and hand twist the wires together.
    • Slide the tubing over the bare wires and heat up the shrink tubing to keep the connection from coming apart easily.
  8. Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 8 中的图像 1,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 8 中的图像 2,3 Sky Viper v950HD Motor Replacement with Quick Connect Motor: 步骤 8 中的图像 3,3
    • I was replacing the motor with red and black wires in the previous step and this is what the motor with the white and red wire looks like when connected.
    • Carefully tuck the wired in the side of the arm and replace the cover.
    • Make sure you do not have any of the wires in a place that can be pinched or damaged by reassembly.
    • Now you are ready to put everything back and you now have a Sky Viper with replaceable motors.
    Super explanation sir easy to adhere. Although come to find out my back right motor was not damaged other than the red wire was severed very close to where it goes into the motor . Can I put a drop of soldier to adhere it to the top of the motor itself or will that short it out?? . There is only a centimeter length of wire coming out of the top. I couldn’t twist it to connect.
    capitol city - 回复
    If you have the soldering skills then definitely but do not forget to insulate the area so the solder or any bare wire do not come into contact with anything.
    Miguel Rodriguez -
结论
3等其他人完成本指南。
一条评论
Would this work with replacing a motor on the Sky Viper s1700 Stunt Drone?
Brian Esparza - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 7,596
