简介
New motors and Gears from the Company are out of stock. Provided your gears are fine, I will show you how to replace a motor with a quick connect motor.
你所需要的
First you will need a Phillips PH0 screwdriver, shrink tubing that fits the thin wire, heat gun or lighter, Female Mini JST plug, and new or harvested motor (WLToys V949 motors work well).
Put the entire assembly back and put the screws back in place.
Cut the wires at an offset and strip all the wires.
Place a small 14mm piece of heat shrink tubing on the wire, match black to black and red to red in this case and hand twist the wires together.
Slide the tubing over the bare wires and heat up the shrink tubing to keep the connection from coming apart easily.
I was replacing the motor with red and black wires in the previous step and this is what the motor with the white and red wire looks like when connected.
Carefully tuck the wired in the side of the arm and replace the cover.
Make sure you do not have any of the wires in a place that can be pinched or damaged by reassembly.
Now you are ready to put everything back and you now have a Sky Viper with replaceable motors.
Super explanation sir easy to adhere. Although come to find out my back right motor was not damaged other than the red wire was severed very close to where it goes into the motor . Can I put a drop of soldier to adhere it to the top of the motor itself or will that short it out?? . There is only a centimeter length of wire coming out of the top. I couldn’t twist it to connect.
If you have the soldering skills then definitely but do not forget to insulate the area so the solder or any bare wire do not come into contact with anything.
3等其他人完成本指南。
Where do I get a motor for my quad copter that is the Sky Viper v950HD in hopes of fixing the 2 stuck propellers?
DHS RIDER - 回复
Any place including Amazon or Ebay that sells the WLToys V949 motors. They are a perfect fit when fully seated and have metal cogs instead on plastic ones but they need to be fully seated .
Miguel Rodriguez - 回复
