你所需要的
Place the drone with the top side facing up.
Remove the blade cover.
Remove the rotor blade.
Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
Remove the blade lockstitch.
Lay down the drone so the battery side is facing up.
Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
Repeat previous bullet for each arm (20 screws in total).
Unscrew the two .8cm screws on the bottom of the holding mechanism with the Phillips 0 Screwdriver.
Remove the motor from the holding mechanism.
3等其他人完成本指南。
