跳转到主内容
Sky Thunder HD 8500WH Lower and Upper Body Replacement
你所需要的
  1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: 步骤 1 中的图像 1,3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: 步骤 1 中的图像 2,3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: 步骤 1 中的图像 3,3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: 步骤 2 中的图像 1,2 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: 步骤 2 中的图像 2,2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: 步骤 3 中的图像 1,3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: 步骤 3 中的图像 2,3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: 步骤 3 中的图像 3,3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Lower and Upper Body Replacement: 步骤 4 中的图像 1,2 Sky Thunder HD 8500WH Lower and Upper Body Replacement: 步骤 4 中的图像 2,2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 123
