跳转到主内容
Sky 6.0Q Top Motherboard Replacement
你所需要的
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: 步骤 1 中的图像 1,1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: 步骤 2 中的图像 1,1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: 步骤 3 中的图像 1,2 Sky 6.0Q Top Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: 步骤 5 中的图像 1,3 Sky 6.0Q Top Motherboard Replacement: 步骤 5 中的图像 2,3 Sky 6.0Q Top Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: 步骤 7 中的图像 1,1
    • Once the screws are removed, gently lift the top motherboard and replace.
结论
另外一个人完成了本指南。
Monica Difato
于11/06/18注册
429 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Hovde Fall 2018 IUPUI, Team S1-G3, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 20
总计 478
