跳转到主内容
Sky 6.0Q Front Camera Replacement
你所需要的
  1. Sky 6.0Q Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Front Camera Replacement: 步骤 2 中的图像 1,1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Front Camera Replacement: 步骤 3 中的图像 1,2 Sky 6.0Q Front Camera Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Front Camera Replacement: 步骤 4 中的图像 1,2 Sky 6.0Q Front Camera Replacement: 步骤 4 中的图像 2,2
    • Disconnect the electronic adapter connecting the camera to the top mother board.
    • Once disconnected, remove the camera and replace with new camera. If necessary, use the spudger to help remove the camera.
    • To reattach front camera electrical connection, gently press piece back in place.
结论
另外一个人完成了本指南。
Robert Berardi
于11/06/18注册
247 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Hovde Fall 2018 IUPUI, Team S1-G3, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 21
总计 260
