跳转到主内容
Sky 6.0Q Battery Replacement
你所需要的
  1. Sky 6.0Q Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: 步骤 2 中的图像 1,1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: 步骤 3 中的图像 1,2 Sky 6.0Q Battery Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: 步骤 5 中的图像 1,1
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: 步骤 6 中的图像 1,1
    • Once separated, remove battery and replace with a new battery.
结论
2等其他人完成本指南。
Monica Difato
于11/06/18注册
429 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Hovde Fall 2018 IUPUI, Team S1-G3, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 51
总计 2,334
