跳转到主内容
Skullcandy Lowrider Wiring Repair
你所需要的
  1. Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: 步骤 1 中的图像 1,3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: 步骤 1 中的图像 2,3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: 步骤 1 中的图像 3,3
    • If your wire is severed, the first step is removing the rubber coating to expose both ends of the severed wire.
    • Do this by wedging it in a sharp crevice and pulling at the rubber coating. It should strip just the rubber coating. The small wedge in a spudger should suffice.
  2. Skullcandy Lowrider Wiring Repair: 步骤 2 中的图像 1,2 Skullcandy Lowrider Wiring Repair: 步骤 2 中的图像 2,2
    • Now that the internal wires have been exposed, take one end and group all similarly colored wires together.
    • Do the same for the other severed wire.
  3. Skullcandy Lowrider Wiring Repair: 步骤 3 中的图像 1,3 Skullcandy Lowrider Wiring Repair: 步骤 3 中的图像 2,3 Skullcandy Lowrider Wiring Repair: 步骤 3 中的图像 3,3
    • Twist the green wires from both ends of the severed wire together.
    • Cover in electrical tape.
  4. Skullcandy Lowrider Wiring Repair: 步骤 4 中的图像 1,1
    • Do the same for all matching wires on both ends.
    • Cover completely in electrical tape.
结论
Ryley
于01/16/15注册
273 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 619
