跳转到主内容
Determining Wire Connectivity for Skullcandy Lowrider
你所需要的
  1. Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: 步骤 1 中的图像 1,2 Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: 步骤 1 中的图像 2,2
    • Pull the edge of the pad where it meets the plastic of the ear-cup to separate the padding from the ear pad.
  2. Determining Wire Connectivity for Skullcandy Lowrider: 步骤 2 中的图像 1,2 Determining Wire Connectivity for Skullcandy Lowrider: 步骤 2 中的图像 2,2
    • Use the small Phillips screwdriver to remove three 8mm screws on the surface of the earphones.
  3. Determining Wire Connectivity for Skullcandy Lowrider: 步骤 3 中的图像 1,1
    • Now that the screws have been removed, use your hands to separate the plate from the rest of headphone.
    • Here, you will be able to check the connectivity of your auxiliary cord to its port in an appropriate ear-cup.
  4. Determining Wire Connectivity for Skullcandy Lowrider: 步骤 4 中的图像 1,1
    • Now that you have removed the plate you can check the wiring connectivity. If the wire is not connected to any sources inside the ear-cup, as shown in the image to the right, then this is the reason that your headphone(s) are not working.
    • Now that you have verified your problem, refer to the guide Skullcandy Lowrider Wiring Repair to fix the loose wiring.
结论
Ryley
于01/16/15注册
273 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 977
