跳转到主内容
Skullcandy Crusher Wireless Folding Hinge Replacement
你所需要的
  1. Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: 步骤 1 中的图像 1,3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: 步骤 1 中的图像 2,3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: 步骤 1 中的图像 3,3
    • Extend and fold the hinge of the headphones you are trying to replace.
  2. Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 2 中的图像 1,3 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 2 中的图像 2,3 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 2 中的图像 3,3
    • Remove two 14 mm Torx T6 screws on the underside of the headband.
  3. Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 3 中的图像 1,3 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 3 中的图像 2,3 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 3 中的图像 3,3
    • Pry the speaker away from the headband with a slight force.
  4. Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 4 中的图像 1,3 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 4 中的图像 2,3 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 4 中的图像 3,3
    • Remove two 5 mm Phillips #1 screws on the underside of the headband.
  5. Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 5 中的图像 1,2 Skullcandy Crusher Wireless Folding Hinge Replacement: 步骤 5 中的图像 2,2
    • Remove the top plastic part of the hinge.
结论
10等其他人完成本指南。
Val
于03/31/22注册
1,104 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 的会员
UMASSD-GURGEL-S22S1G33
1 名成员
创作了12篇指南
7条评论
Hello. Any idea where can i buy the folding hinge from? thx!
Liviu - 回复
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
Menno de Gier - 回复
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
Eatfire - 回复
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
https://guide-images.cdn.ifixit.com/igi/...
Cus7od35 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 44
过去 30 天: 176
总计 9,116
