跳转到主内容
SkullCandy Hesh Size Adjuster Replacement
你所需要的
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: 步骤 1 中的图像 1,2 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: 步骤 1 中的图像 2,2
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: 步骤 4 中的图像 1,2 SkullCandy Hesh Size Adjuster Replacement: 步骤 4 中的图像 2,2
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: 步骤 5 中的图像 1,1
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: 步骤 6 中的图像 1,1
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
结论
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
于01/15/15注册
247 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 875
