跳转到主内容
加入维修社区 - 创建账户
Skirt Lining Replacement
你所需要的
  1. Skirt Lining Replacement, Lining: 步骤 1 中的图像 1,2 Skirt Lining Replacement, Lining: 步骤 1 中的图像 2,2
    • Cut out the old or damaged skirt lining. This can be done using a pair of scissors, or a razor blade/seam ripper if you have one.
    • Blades might give you a neater finish after this step but take longer to use.
    • Be careful when using sharp objects.
  2. Skirt Lining Replacement: 步骤 2 中的图像 1,2 Skirt Lining Replacement: 步骤 2 中的图像 2,2
    • After threading the needle, take some new lining (chiffon or silk material), iron it out, and make sure the lining isn't longer than the actual skirt.
  3. Skirt Lining Replacement: 步骤 3 中的图像 1,3 Skirt Lining Replacement: 步骤 3 中的图像 2,3 Skirt Lining Replacement: 步骤 3 中的图像 3,3
    • Gently insert the threaded needle. Be careful not to prick your finger.
    • Push through the skirt fabric from below.
    • Pull the needle all the way out to form a stitch.
  4. Skirt Lining Replacement: 步骤 4 中的图像 1,1
    • Continue with step 3 until you create stitches around the whole waistband of your skirt.
    • It should look somewhat like this when you make it halfway around the waistband of the skirt.
  5. Skirt Lining Replacement: 步骤 5 中的图像 1,1
    • Cut out extra fabric if you have any, and here's what the waistline of your skirt should look like.
    • Try it on!
终点
另外一个人完成了本指南。
Rena
于01/11/24注册
121 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 587
