跳转到主内容
Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement
你所需要的
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Un-clip Battery: 步骤 1 中的图像 1,1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Battery: 步骤 2 中的图像 1,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Battery: 步骤 2 中的图像 2,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Handle: 步骤 3 中的图像 1,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Handle: 步骤 3 中的图像 2,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Handle: 步骤 3 中的图像 3,3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  4. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove Gauge: 步骤 4 中的图像 1,1
    • Hold drill upright with one hand and slide the gauge backwards to remove it with the other.
  5. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the screw from the chuck sleeve: 步骤 5 中的图像 1,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the screw from the chuck sleeve: 步骤 5 中的图像 2,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the screw from the chuck sleeve: 步骤 5 中的图像 3,3
    • The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
  6. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the chuck sleeve: 步骤 6 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the chuck sleeve: 步骤 6 中的图像 2,2
    • The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
  7. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the screws from the adjustable clutch: 步骤 7 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the screws from the adjustable clutch: 步骤 7 中的图像 2,2
    • Set the adjustable clutch to the "1" setting before beginning. This will make it easier to remove.
    • The adjustable clutch is held on by 2 20mm T10 Torx screws. Insert a T10 Torx screwdriver and rotate it counterclockwise to loosen and remove each screw.
  8. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the adjustable clutch: 步骤 8 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove the adjustable clutch: 步骤 8 中的图像 2,2
    • Firmly grip the outside of the adjustable clutch and pull it off.
    • There is a metal washer behind the adjustable clutch that holds in 12 small ball bearings. Hold the drill so it is pointing up slightly so the washer and bearings do not fall out.
  9. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove front screws: 步骤 9 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove front screws: 步骤 9 中的图像 2,2
    • Locate 4 screws on front of the drill. Remove using Torx T10
    • Remove front casing piece.
  10. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove back screws: 步骤 10 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove back screws: 步骤 10 中的图像 2,2
    • Locate 4 screws on back of the drill.Remove using Torx T10.
    • Remove back casing piece.
  11. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove side screws: 步骤 11 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Remove side screws: 步骤 11 中的图像 2,2
    • Locate 4 screws on side of the drill. Remove using Torx T10
  12. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Case removal: 步骤 12 中的图像 1,1
    • After all screws have been removed both side casings can be taken apart.
  13. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Disconnect trigger: 步骤 13 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Disconnect trigger: 步骤 13 中的图像 2,2
    • Disconnect all wiring on top of trigger coming from motor and board.
  14. Skil X-Drive 18V Cordless Drill Model No. 2887 Trigger Replacement, Connect new trigger: 步骤 14 中的图像 1,1
    • Reconnect all wiring to your new trigger
结论
Daniel
于09/22/14注册
143 声望
撰写一个指南
团队
USF Tampa, Team 2-3, Blackwell Fall 2014 USF Tampa, Team 2-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G3
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 627
