当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
即将完成!
终点
一条评论
For my drill, the Torx screw had to be rotated *counter-clockwise to remove. I'm not sure if that was an error in step #5 or some drills are different.
Thank you for the location of those screws btw.
"Step 5 — Remove the chuck sleeve
The threaded hole the screw was in is in the
shape of a 6-point star. Insert a T40 Torx Key
and rotate it *clockwise to loosen and remove
the chuck sleeve."
Joe Bailey - 回复
