跳转到主内容
Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement
你所需要的
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Un-clip Battery: 步骤 1 中的图像 1,1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: 步骤 2 中的图像 1,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: 步骤 2 中的图像 2,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
    hi my name is Joe have a set of skil 4 pc sawsal drill skill saw 18 w need to replace a battery x drive same as Pic on this page 2887 18v someone please if anyone could guide me we're and $ it would be thank you
    Joe G - 回复
    Release button apears to be locked. Am I doing something wrong?
    John - 回复
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: 步骤 3 中的图像 1,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: 步骤 3 中的图像 2,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: 步骤 3 中的图像 3,3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  4. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: 步骤 4 中的图像 1,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: 步骤 4 中的图像 2,3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: 步骤 4 中的图像 3,3
    • The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
  5. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the chuck sleeve: 步骤 5 中的图像 1,2 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the chuck sleeve: 步骤 5 中的图像 2,2
    • The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
结论
Jameson
于09/23/14注册
258 声望
创作了2篇指南
团队
USF Tampa, Team 2-3, Blackwell Fall 2014 USF Tampa, Team 2-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G3
5 名成员
创作了9篇指南
一条评论
For my drill, the Torx screw had to be rotated *counter-clockwise to remove. I'm not sure if that was an error in step #5 or some drills are different.
Thank you for the location of those screws btw.
"Step 5 — Remove the chuck sleeve
and rotate it *clockwise to loosen and remove
the chuck sleeve."
Joe Bailey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,506
