跳转到主内容
Skil 88 Motor Replacement
你所需要的
  1. Skil 88 Motor Replacement, Disassembling Skil 88 Front Housing: 步骤 1 中的图像 1,1
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Replacement: 步骤 2 中的图像 1,2 Skil 88 Motor Replacement: 步骤 2 中的图像 2,2
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Replacement, Motor: 步骤 3 中的图像 1,2 Skil 88 Motor Replacement, Motor: 步骤 3 中的图像 2,2
    • Remove the gear that is threaded onto the divider.
  4. Skil 88 Motor Replacement: 步骤 4 中的图像 1,2 Skil 88 Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the divider from the rear housing.
    • The motor may come out along with the divider.
  5. Skil 88 Motor Replacement: 步骤 5 中的图像 1,2 Skil 88 Motor Replacement: 步骤 5 中的图像 2,2
    • Pull out the motor.
  6. Skil 88 Motor Replacement: 步骤 6 中的图像 1,3 Skil 88 Motor Replacement: 步骤 6 中的图像 2,3 Skil 88 Motor Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
    • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
    • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
结论
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
于10/10/10注册
365 声望
创作了7篇指南
团队
Cal Poly, Team 5-17, Maness Fall 2010 Cal Poly, Team 5-17, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G17
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 662
