跳转到主内容
Skil 88 Motor Housing Replacement
你所需要的
  1. Skil 88 Motor Housing Replacement, Disassembling Skil 88 Front Housing: 步骤 1 中的图像 1,1
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Housing Replacement: 步骤 2 中的图像 1,2 Skil 88 Motor Housing Replacement: 步骤 2 中的图像 2,2
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Housing Replacement, Trigger Housing: 步骤 3 中的图像 1,2 Skil 88 Motor Housing Replacement, Trigger Housing: 步骤 3 中的图像 2,2
    • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  4. Skil 88 Motor Housing Replacement: 步骤 4 中的图像 1,3 Skil 88 Motor Housing Replacement: 步骤 4 中的图像 2,3 Skil 88 Motor Housing Replacement: 步骤 4 中的图像 3,3
    • Separate the cord from the handle.
  5. Skil 88 Motor Housing Replacement, Motor Housing: 步骤 5 中的图像 1,2 Skil 88 Motor Housing Replacement, Motor Housing: 步骤 5 中的图像 2,2
    • Remove the inner divider.
  6. Skil 88 Motor Housing Replacement: 步骤 6 中的图像 1,1
    • Remove the two 1" flathead screws located at the top and bottom of the motor housing.
  7. Skil 88 Motor Housing Replacement: 步骤 7 中的图像 1,2 Skil 88 Motor Housing Replacement: 步骤 7 中的图像 2,2
    • Pull the motor housing out.
    • The wires from the trigger housing should follow the motor housing.
  8. Skil 88 Motor Housing Replacement: 步骤 8 中的图像 1,2 Skil 88 Motor Housing Replacement: 步骤 8 中的图像 2,2
    • After you have placed the motor housing back into the drill during reassembly, thread the wires down to the handle using tweezers.
    • Plug the forked wire into the socket at the back of the motor housing using tweezers.
结论
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
于10/10/10注册
365 声望
创作了7篇指南
团队
Cal Poly, Team 5-17, Maness Fall 2010 Cal Poly, Team 5-17, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G17
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,884
