当前版本的文档还未经巡查,您可以查看最新的已查核版本。
With a 13mm wrench, remove the axle nut located in the center of the wheel.
Set the axle nut aside, and remove the wheel.
Position the wheel at the end of the axle.
To remove the bearings, gently pry the wheel at a downward angle.
Perform this prying process on both sides of the wheel.
A bearing spacer should fall out once the bearings are removed.
Position the new wheel on a flat surface.
Press the bearing into the hole of the new wheel.
Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
With the bearings in place, the wheel can be placed on the axle.
Tighten the axle nut firmly.
Do not over tighten. The wheel should spin freely.
Repeat steps 1-9 for the remaining wheels.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
