当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
这个步骤还没有翻译 帮忙翻译一下
While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
Repeat steps 1 - 6 to install the second truck.
2等其他人完成本指南。
