跳转到主内容
SiriusXM Onyx Plus Buttons Replacement
你所需要的
  1. SiriusXM Onyx Plus Buttons Replacement, Case: 步骤 1 中的图像 1,1
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Buttons Replacement: 步骤 2 中的图像 1,3 SiriusXM Onyx Plus Buttons Replacement: 步骤 2 中的图像 2,3 SiriusXM Onyx Plus Buttons Replacement: 步骤 2 中的图像 3,3
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Buttons Replacement: 步骤 3 中的图像 1,1
    • Once unclipped, separate the back casing from the device.
  4. SiriusXM Onyx Plus Buttons Replacement, Buttons: 步骤 4 中的图像 1,2 SiriusXM Onyx Plus Buttons Replacement, Buttons: 步骤 4 中的图像 2,2
    • Remove the three 5mm JIS #00 screws from the motherboard.
  5. SiriusXM Onyx Plus Buttons Replacement: 步骤 5 中的图像 1,1
    • Unlatch the two clips that hold the motherboard in place.
  6. SiriusXM Onyx Plus Buttons Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard up and out of the frame.
  7. SiriusXM Onyx Plus Buttons Replacement: 步骤 7 中的图像 1,2 SiriusXM Onyx Plus Buttons Replacement: 步骤 7 中的图像 2,2
    • Holding the front casing in your hand, push the button panels out of the casing.
    • There are two buttons panels: Navigation panel and the Channel Number panel
结论
Angel Rivera
于01/25/18注册
532 声望
创作了5篇指南
团队
USF Tampa, Team S7-G2, Passmore Spring 2018 USF Tampa, Team S7-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 240
