简介
Replace your LCD display only as a last option. Since the LCD display uses a flexible flat cable(FFC), improperly inserting the cable may cause damage to your device.
你所需要的
From the back of the device, slide the back panel downwards to unlock the panel.
Lift the panel up, exposing the battery.
Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
即将完成!
结论
另外一个人完成了本指南。
