跳转到主内容
Sirius Stiletto 2 Front Cover Replacement
你所需要的
  1. Sirius Stiletto 2 Front Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 Front Cover Replacement: 步骤 2 中的图像 1,2 Sirius Stiletto 2 Front Cover Replacement: 步骤 2 中的图像 2,2
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 Front Cover Replacement, Front Cover: 步骤 3 中的图像 1,1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 Front Cover Replacement: 步骤 4 中的图像 1,2 Sirius Stiletto 2 Front Cover Replacement: 步骤 4 中的图像 2,2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
结论
Benjamin Her
于01/21/15注册
555 声望
创作了5篇指南
团队
USF Tampa, Team 6-6, Brown Winter 2015 USF Tampa, Team 6-6, Brown Winter 2015 的会员
USFT-BROWN-W15S6G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 286
