简介
The bulk of the work for this guide is removing the front plate. Sirius put in some serious effort to keep it from ever coming off.
The Aux board may become damaged with frequent use as stresses are applied via the attached headphone jack port. It is relatively simple and fast to remove.
你所需要的
Pry the speaker covers up gently from their sides by pulling up on the four corner posts that hold the cover in place.
Turn the device so that its front is visible.
Remove the channel dial by pulling up on the dial firmly.
Remove the S50 by pulling it up and off of its connecting posts.
Use an iFixit opening tool to pull up both sides of the speaker plate. They should come up easily. Pull firmly on the center to break the adhesive.
Remove the single 8 mm screw using a Phillips #00 screwdriver.
Disconnect the bundled cable connecter from the board.
