跳转到主内容
Singular Cylinder Kwikset Deadbolt Replacement
你所需要的
  1. Singular Cylinder Kwikset Deadbolt Replacement, Singular Cylinder Kwikset Deadbolt: 步骤 1 中的图像 1,1
    • Turn the lock clockwise until two screws are visible.
  2. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 2 中的图像 1,1
    • Remove both screws from the lock cylinder using a Phillips #3 screwdriver.
  3. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 3 中的图像 1,1
    • Remove the lock cylinder from the door.
  4. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 4 中的图像 1,1
    • Remove the pin and key cylinder from both of the secondary and primary support cylinders.
  5. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 5 中的图像 1,1
    • Remove the secondary support cylinder from the primary support cylinder.
  6. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 6 中的图像 1,1
    • Remove the primary cylinder support from the door.
  7. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 7 中的图像 1,1
    • Remove both of the 3/4 inch screws from the face of the latch mechanism using a Phillips #3 screwdriver.
  8. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 8 中的图像 1,1
    • Remove the latch mechanism with the latch face from the door.
  9. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 9 中的图像 1,1
    • Insert the new latch mechanism with the latch face in the door. A capital letter "A" should face upward in the latch face.
  10. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 10 中的图像 1,1
    • Reinsert both of the screws in the latch face using a Phillips #3 screwdriver.
  11. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 11 中的图像 1,1
    • Insert the primary support cylinder in the door.
  12. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 12 中的图像 1,1
    • Insert the secondary support cylinder in the door.
  13. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 13 中的图像 1,1
    • Insert the new pin and key cylinder in both the primary and secondary support cylinders.
  14. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 14 中的图像 1,1
    • Insert the new lock cylinder in the door by aligning the lock with the pin of the key cylinder.
  15. Singular Cylinder Kwikset Deadbolt Replacement: 步骤 15 中的图像 1,1
    • Insert both of the screws in the lock cylinder using a Phillips #3 screwdriver.
结论
Please follow the link listed to purchase the singular cylinder kwikset deadbolt package or type in Google “singular cylinder kwikset deadbolt” to find the appropriate parts, if not interested to purchase from the link listed.
Jules Torilus
于04/24/21注册
241 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 41
总计 1,213
