跳转到主内容
Single-Speed Bicycle Chain Replacement
你所需要的
  1. Single-Speed Bicycle Chain Replacement, Chain: 步骤 1 中的图像 1,2 Single-Speed Bicycle Chain Replacement, Chain: 步骤 1 中的图像 2,2
    • Flip the bike upside down for easy access to the rear wheel and chain.
  2. Single-Speed Bicycle Chain Replacement: 步骤 2 中的图像 1,2 Single-Speed Bicycle Chain Replacement: 步骤 2 中的图像 2,2
    • Use either an Allen or crescent wrench to loosen the nuts of the rear wheel of the bike. Make sure to do this on both sides of the wheel.
    • This step will require a 5mm Allen wrench or a crescent wrench, depending on the type of wheels you have.
  3. Single-Speed Bicycle Chain Replacement: 步骤 3 中的图像 1,2 Single-Speed Bicycle Chain Replacement: 步骤 3 中的图像 2,2
    • Place the chain breaker tool over the old chain.
    • Insert a link of the old chain into the chain breaker tool.
  4. Single-Speed Bicycle Chain Replacement: 步骤 4 中的图像 1,3 Single-Speed Bicycle Chain Replacement: 步骤 4 中的图像 2,3 Single-Speed Bicycle Chain Replacement: 步骤 4 中的图像 3,3
    • Turn the knob on the chain breaker tool until the pin within the chain has popped out.
    • Remove the old chain.
    • This step may take some finesse to ensure that the pin falls out.
  5. Single-Speed Bicycle Chain Replacement: 步骤 5 中的图像 1,2 Single-Speed Bicycle Chain Replacement: 步骤 5 中的图像 2,2
    • Unbox the new chain and place it on the chain ring.
    • Align the rings with the gears to ensure a proper fit.
  6. Single-Speed Bicycle Chain Replacement: 步骤 6 中的图像 1,3 Single-Speed Bicycle Chain Replacement: 步骤 6 中的图像 2,3 Single-Speed Bicycle Chain Replacement: 步骤 6 中的图像 3,3
    • Wrap the chain around the cog of the rear wheel and bring the two ends of the chain together.
    • The chain should be long enough so that it can move up and down ~1/2 inch when secured.
    • Remove the excess chain using the chain breaker tool. Refer to steps 3 and 4 for how to use the chain breaker tool.
  7. Single-Speed Bicycle Chain Replacement: 步骤 7 中的图像 1,3 Single-Speed Bicycle Chain Replacement: 步骤 7 中的图像 2,3 Single-Speed Bicycle Chain Replacement: 步骤 7 中的图像 3,3
    • Locate the master link of the chain.
    • A master link is a single removable link segment on a bike chain. It connects the two ends of the chain together.
    • Insert the link pins into the two ends of the chain.
  8. Single-Speed Bicycle Chain Replacement: 步骤 8 中的图像 1,2 Single-Speed Bicycle Chain Replacement: 步骤 8 中的图像 2,2
    • Place the link face onto the link pins.
    • The chain is now secured.
  9. Single-Speed Bicycle Chain Replacement: 步骤 9 中的图像 1,3 Single-Speed Bicycle Chain Replacement: 步骤 9 中的图像 2,3 Single-Speed Bicycle Chain Replacement: 步骤 9 中的图像 3,3
    • Once the chain is on, pull the rear wheel back.
    • Tighten the nut on the drive side (right side) of the rear wheel.
    • The drive side of a bike is the side with the gears. This is usually on the right side, as seen in this model.
  10. Single-Speed Bicycle Chain Replacement: 步骤 10 中的图像 1,2 Single-Speed Bicycle Chain Replacement: 步骤 10 中的图像 2,2
    • Push the front end of the rear wheel to the non-drive side (left side) of the wheel. This pulls on the chain, creating tension.
    • Tighten the nut on the non-drive side (left side) of the wheel.
  11. Single-Speed Bicycle Chain Replacement: 步骤 11 中的图像 1,1
    • Repeat the previous step with the drive side (right side) until the wheel is tightened.
    • Ensure that both nuts are tightened evenly.
  12. Single-Speed Bicycle Chain Replacement: 步骤 12 中的图像 1,3 Single-Speed Bicycle Chain Replacement: 步骤 12 中的图像 2,3 Single-Speed Bicycle Chain Replacement: 步骤 12 中的图像 3,3
    • Check the tension in the gear.
    • It is good to have about half an inch of play in the chain in both directions.
结论
另外一个人完成了本指南。
SaniaHey
于01/31/24注册
214 声望
撰写一个指南
团队
UC Davis, Team 1-7, Andersen Winter 2024 UC Davis, Team 1-7, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S1G7
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 37
过去 30 天: 158
总计 2,271
