跳转到主内容
加入维修社区 - 创建账户
Singer Simple Sewing Machine (Model 2263) Needle Replacement
你所需要的
  1. Singer Simple Sewing Machine (Model 2263) Needle Replacement, Needle: 步骤 1 中的图像 1,1
    • Turn off the sewing machine and unplug it.
  2. Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 2 中的图像 1,1
    • Push the back lever up and remove the presser foot.
  3. Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 3 中的图像 1,1
    • Raise the needle bar by turning the handwheel toward you.
  4. Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 4 中的图像 1,1
    • With the provided Singer screwdriver or a flat-head screwdriver, loosen the clamp screw by turning it toward you.
  5. Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 5 中的图像 1,1
    • Remove the broken needle.
  6. Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 6 中的图像 1,2 Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 6 中的图像 2,2
    • Insert the new needle with the flat side (the side with the numbers) facing the back of the sewing machine. Tighten the clamp screw by turning it toward the back.
  7. Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 7 中的图像 1,2 Singer Simple Sewing Machine (Model 2263) Needle Replacement: 步骤 7 中的图像 2,2
    • Put the presser foot back on by pushing the back lever up and guiding the bar on the presser foot onto the hook of the needle bar. Release the lever to secure.
结论
Once the pressure foot is attached, thread the needle before plugging in the sewing machine and turning it on.
Renee Allred
于09/15/23注册
145 声望
撰写一个指南
1指南评论
Please assist me with adjusting needle bar height for Singer Simple 2263 cannot find how to adjust hook timing either have watched sooo many videos none have helped me
Maria L. Soto - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 91
总计 1,109
