跳转到主内容
加入维修社区 - 创建账户
Sigrow Soil Pro Assembly
你所需要的
  1. Sigrow Soil Pro Assembly, Ensure you have the components: 步骤 1 中的图像 1,1
    • Watermelon Soil Sensor
    • b07 PCB [coated]
    • body b07
    • hat b07
    • inside bottom plate b07
    • You will need a flat-head screw driver (1.5 to 2.0 mm)
  2. Sigrow Soil Pro Assembly, Insertion cable: 步骤 2 中的图像 1,2 Sigrow Soil Pro Assembly, Insertion cable: 步骤 2 中的图像 2,2
    • Insert watermelon cable through case and inside bottom plate
    • Pay attention that the temperature humidity sensor slot is on the left side
  3. Sigrow Soil Pro Assembly, Connect soil sensor to pcb: 步骤 3 中的图像 1,2 Sigrow Soil Pro Assembly, Connect soil sensor to pcb: 步骤 3 中的图像 2,2
    • Ensure all the ports of the connector are open
    • These 4 ports are open!
    • This port is closed!
    • To open the port unscrew counterclockwise
    • Follow the colour guideline and ensure all the cables are fully inserted.
    • Close the ports tightly by rotating clockwise. One at a time is easier.
  4. Sigrow Soil Pro Assembly, Slide pcb in: 步骤 4 中的图像 1,3 Sigrow Soil Pro Assembly, Slide pcb in: 步骤 4 中的图像 2,3 Sigrow Soil Pro Assembly, Slide pcb in: 步骤 4 中的图像 3,3
    • Ensure 8 to 12 cm of cable are left inside the case facing upwards
    • Slide pcb in.
    • Quality Control: If the PCB doesn't slide in the case or the fit is too loose (PCB slides downwards by itself when inverted) OR the pcb makes a shaki sound when you shake the case -> request new case or contact a senior sigrow technician
  5. Sigrow Soil Pro Assembly, Close the case with hat: 步骤 5 中的图像 1,2 Sigrow Soil Pro Assembly, Close the case with hat: 步骤 5 中的图像 2,2
    • Quality Control: Looks easy but the hat shouldn't be too tight (no need to force to insert it) and not too loose (doesn't fall when sensor upside down)
  6. Sigrow Soil Pro Assembly, Place in inventory box: 步骤 6 中的图像 1,1
    • Boxes of 10, sensors on borders, cables towards the center so we can pull them easily later
结论
In case of doubt reach a senior sigrow technician
另外一个人完成了本指南。
Sigrow
于05/14/20注册
1,075 声望
创作了5篇指南
团队
Sigrow Sigrow 的会员
Community
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 215
