跳转到主内容
加入维修社区 - 创建账户
Sigrow Soil Pro + Assembly
你所需要的
  1. Sigrow Soil Pro + Assembly, Gather materials: 步骤 1 中的图像 1,3 Sigrow Soil Pro + Assembly, Gather materials: 步骤 1 中的图像 2,3 Sigrow Soil Pro + Assembly, Gather materials: 步骤 1 中的图像 3,3
    • PCB RR02 or higher 'coated
    • Sigrow Soil Sensor
    • (Top left to bottom right) Case Body +, hat +, solar, bottom inner plate +, fan holder.
    • Sunon Fan 5VDC
    • Solar panel 110x80
    • Tools (top-left to bottom right) : tin, soldering station, flat head screw driver, cable peeler, pliers glue gun (optional).
    • Cable double insulaton: +6 wires, 20 cm
  2. Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: 步骤 2 中的图像 1,3 Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: 步骤 2 中的图像 2,3 Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: 步骤 2 中的图像 3,3
    • Cable length is aprox 20-22 cm
    • Peel both ends, keep the non-peeled part short
    • Group them, twist and solder them together
    • On the opposite side you will only keep two colours: black and yellow
  3. Sigrow Soil Pro + Assembly, Solder cable solar panel: 步骤 3 中的图像 1,3 Sigrow Soil Pro + Assembly, Solder cable solar panel: 步骤 3 中的图像 2,3 Sigrow Soil Pro + Assembly, Solder cable solar panel: 步骤 3 中的图像 3,3
    • Solder
    • Remove the plastic sheet
    • Slide solar panel in parasol
  4. Sigrow Soil Pro + Assembly, Fan mount: 步骤 4 中的图像 1,1
    • Insert fan in fan holder
    • Pay attention to the fan air flow direction, it should be upwards
  5. Sigrow Soil Pro + Assembly, Peripherals: 步骤 5 中的图像 1,2 Sigrow Soil Pro + Assembly, Peripherals: 步骤 5 中的图像 2,2
    • From top to bottom:
    • Solar Panel mounted and with cable soldered (side with Sigrow letters)
    • Fan (cable enters from bottom)
    • Soil Sensor (cable enters from Sigrow 3 circles logo side)
  6. Sigrow Soil Pro + Assembly, Attach fan holder to main case+: 步骤 6 中的图像 1,2 Sigrow Soil Pro + Assembly, Attach fan holder to main case+: 步骤 6 中的图像 2,2
    • Fan holder should be inserted in main body case by pressure
    • If there's not a tight fit there are 2 options:
    • Option 1: Request a new fan holder
    • Option 2: Use the hot glue gun.
    • tight fit could be interpreted as: "if with very hard shaken the fan holder and main case will not disconnect and stay solidly attached.'
  7. Sigrow Soil Pro + Assembly, Bottom inner plate: 步骤 7 中的图像 1,2 Sigrow Soil Pro + Assembly, Bottom inner plate: 步骤 7 中的图像 2,2
    • Rectangular gap (for temperature humidity sensor) goes slightly in the left.
    • Bottom right tiny circular hole is for the fan cables
  8. Sigrow Soil Pro + Assembly, Confirm orientation: 步骤 8 中的图像 1,2 Sigrow Soil Pro + Assembly, Confirm orientation: 步骤 8 中的图像 2,2
    • Sigrow 3 circles side-> Soil Sensor
    • Letter side -> Solar panel
  9. Sigrow Soil Pro + Assembly, Soil Sensor connection: 步骤 9 中的图像 1,3 Sigrow Soil Pro + Assembly, Soil Sensor connection: 步骤 9 中的图像 2,3 Sigrow Soil Pro + Assembly, Soil Sensor connection: 步骤 9 中的图像 3,3
    • Insert cables into connector, check in 3rd image in this step that the ports are open
    • Use pliers to cut white cable
  10. Sigrow Soil Pro + Assembly, Solder fan cables: 步骤 10 中的图像 1,2 Sigrow Soil Pro + Assembly, Solder fan cables: 步骤 10 中的图像 2,2
    • Black ground
    • Red positive
    • Cut with pliers cable excess from behind
  11. Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: 步骤 11 中的图像 1,3 Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: 步骤 11 中的图像 2,3 Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: 步骤 11 中的图像 3,3
    • Cables enter from the back of the PCB
    • Yellow is positive
    • Black is negative (closer to the edge)
    • Cut with pliers cable and tin excess
    • Soldering station is very hot, dont touch it with your hands
  12. Sigrow Soil Pro + Assembly, Insert PCB in case - Cable details: 步骤 12 中的图像 1,2 Sigrow Soil Pro + Assembly, Insert PCB in case - Cable details: 步骤 12 中的图像 2,2
    • It's great to leave some extra cables in good shape
    • ~10 cm for the soil sensor bended as inverted-U
    • Twist the fan cable (it's very long) and bend as inverted-U
    • if PCB doesn't slide down with a gentle push or slides out too easy when case is upside down new case should be requested.
  13. Sigrow Soil Pro + Assembly, Closing the case: 步骤 13 中的图像 1,2 Sigrow Soil Pro + Assembly, Closing the case: 步骤 13 中的图像 2,2
    • After sliding PCB in, connect the solar parasol and the hat +
    • If the fit is not great inform Sigrow senior technician
  14. Sigrow Soil Pro + Assembly: 步骤 14 中的图像 1,1
    • Congrats, you have completed a Soil Pro+
    • Please request from your Senior technician the latest packaging guidelines
结论
In case of doubt contact manufacturing@sigrow.com
Sigrow
于05/14/20注册
1,075 声望
创作了5篇指南
团队
Sigrow Sigrow 的会员
Community
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 304
