跳转到主内容
Signode BXT3-16 Strapping Combo Tool Spring Replacement
你所需要的
  1. Signode BXT3-16 Strapping Combo Tool Spring Replacement, Spring: 步骤 1 中的图像 1,1
    • Before dismantling the strapping gun, ensure the power source / battery is removed.
  2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 2 中的图像 1,1
    • Turn the strapping gun upside down.
    • Place it on a flat surface to keep the strapping gun stable during repair.
    • There are four Torx T4 screws on the bottom of the tool.
  3. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 3 中的图像 1,3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 3 中的图像 2,3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 3 中的图像 3,3
    • Use the Torx T4 screwdriver to remove the four 25 mm screws from the base plate.
    • Remove the single 25 mm Torx T4 screw from the front side of the strapping gun.
    • Use a Torx T4 screwdriver to remove the two 25 mm screws on the front of the tool.
  4. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 4 中的图像 1,1
    • Rotate the strapping gun to the opposite side.
    • Use the Torx T4 screwdriver to remove the remaining 25 mm screws from the front of the strapping gun.
  5. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 5 中的图像 1,2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 5 中的图像 2,2
    • Rotate the strapping tool to the original position, with the model number and name facing you.
    • Firmly pull the guard plate and the tool apart using both hands.
  6. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 6 中的图像 1,2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 6 中的图像 2,2
    • Use a metal spudger to lift the cutter.
    • Gently, push the spring out from the bottom of the base of the strapping gun.
  7. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 7 中的图像 1,3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 7 中的图像 2,3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 步骤 7 中的图像 3,3
    • Rotate the machine to remove the spring gently by hand.
    • Remove the spring from the base of the strapping tool.
    • Replace with new spring by inserting it the same way it was removed.
结论
3等其他人完成本指南。
Jainam Shah
于02/01/24注册
172 声望
撰写一个指南
团队
York University, Team M-10, Allen Winter 2024 York University, Team M-10, Allen Winter 2024 的会员
YORK-ALLEN-W24SMG10
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 45
总计 843
