跳转到主内容
加入维修社区 - 创建账户
Sigma 24-70 Disassembly
你所需要的
  1. Sigma 24-70 Disassembly, Lens: 步骤 1 中的图像 1,1
    • 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
  2. Sigma 24-70 Disassembly: 步骤 2 中的图像 1,2 Sigma 24-70 Disassembly: 步骤 2 中的图像 2,2
    • Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
  3. Sigma 24-70 Disassembly: 步骤 3 中的图像 1,1
    • Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
结论
9等其他人完成本指南。
Greg
于12/10/12注册
378 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 32
总计 3,716
