简介
If the coffee only sprays weakly out of the two outlets, or only pours out of one of the two outlets, then they are probably blocked with coffee fat. It's difficult to properly clean the component as the aroma of the coffee will always suffer. The replacement part costs less than 4 euros, the replacement is extremely easy and will be described here.
The replacement of the coffee outlet in the Titanium line TK56001 makes more trouble, because you have to open the casing. The guide can be found here.
你所需要的
To the left and right of the coffee outlet you will find two slots on the underside of the front cover.
Insert a spudger in the front edge of this slot and loosen the clips that fasten the front cover.
Pull the front cover forwards and off.
The image shows the machine after the front cover has been taken off. The four slots where the clips were are easily recognizable.
The movable coffee outlet is surrounded by a casing. Place an opening tool in the gap that separates the two halves of the casing.
Slide the tool along the gap, until the front casing becomes loose.
Remove the front casing.
4等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
