跳转到主内容
Siemens-Maquet Servo-i Filters for Gas Modules Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Siemens-Maquet Servo-i Filters for Gas Modules Replacement, Filter for Gas Modules: 步骤 1 中的图像 1,1
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Filters for Gas Modules Replacement: 步骤 2 中的图像 1,1
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Filters for Gas Modules Replacement: 步骤 3 中的图像 1,1
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Filters for Gas Modules Replacement: 步骤 4 中的图像 1,1
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
结论
Maria Brown
于05/04/20注册
196 声望
创作了2篇指南
团队
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 502
