跳转到主内容
Siemens-Maquet Servo-i Battery Module Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
    • Check the battery date. The battery needs replacing after 3 years.
    • The manufacturing date is listed in the format (year-week) on the battery label.
    • Servo-i User Manual page 19.
    • If battery status on touchpad display is red make sure to replace battery modules.
    • At least one battery module must be installed at all times. If not the ventilator will not work properly.
    • Store uninstalled batteries at 15-20 degrees celsius.
  1. Siemens-Maquet Servo-i Battery Module Replacement: 步骤 3 中的图像 1,1
    • Wait for the battery to be fully charged.
    • To check this, press the battery power symbol button on the battery.
    • All four LED's must be lit.
    • Servo-i User Manual page 20.
  2. Siemens-Maquet Servo-i Battery Module Replacement: 步骤 4 中的图像 1,1
    • With gas, patient tubes and test lung connected, let the Servo-i run in a ventilation mode.
    • Disconnect mains power to the unit to allow battery operation.
    • Allow ventilator to run and make sure 'No battery capacity'- alarm is not activated.
    • Servo-i Service Manual 5-2.
  3. Siemens-Maquet Servo-i Battery Module Replacement: 步骤 5 中的图像 1,1
    • The time between the 'Limited battery capacity'- alarm and the 'No battery capacity' alarm must not exceed 7 minutes.
    • The event log contains the records of alarm times.
  4. Siemens-Maquet Servo-i Battery Module Replacement: 步骤 6 中的图像 1,3 Siemens-Maquet Servo-i Battery Module Replacement: 步骤 6 中的图像 2,3 Siemens-Maquet Servo-i Battery Module Replacement: 步骤 6 中的图像 3,3
    • See if the upper part of the module is equipped with a latch. This means it is fixed and follow these instructions to disassemble a battery from the battery module.
    • 1. Locate a small hexagonal wrench or screwdriver.
    • Place the tool in the small hole on the right hand side.
    • 2. Simultaneously push the release button.
    • 3. Remove the tool, while still pressing the release button.
    • 4. Continue to keep the button pressed until the battery pops out.
    • 5. Pull out the battery module.
    • Servo-i Service Manual 4-18.
结论
Monroe Erle
于05/04/20注册
133 声望
撰写一个指南
团队
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 15
总计 1,000
