跳转到主内容
加入维修社区 - 创建账户
Siemens A56 SIM Card Replacement
你所需要的
  1. Siemens A56 SIM Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 SIM Card Replacement: 步骤 2 中的图像 1,1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,3 Siemens A56 SIM Card Replacement, SIM Card: 步骤 3 中的图像 2,3 Siemens A56 SIM Card Replacement, SIM Card: 步骤 3 中的图像 3,3
    • With the phone turned onto its backside, gently slide the metal clasp up to unlock the SIM card.
    • It may be easier to move the clasp with a plastic opening tool, but it is not required.
    • The SIM card will spring up once the clasp is released.
    • Remove the SIM card from phone.
  4. Siemens A56 SIM Card Replacement: 步骤 4 中的图像 1,3 Siemens A56 SIM Card Replacement: 步骤 4 中的图像 2,3 Siemens A56 SIM Card Replacement: 步骤 4 中的图像 3,3
    • To replace the SIM card, insert the card back into the slot.
    • While pressing the SIM card with one finger, slide the metal clasp down to lock the card in place.
终点
另外一个人完成了本指南。
Lauren Young
于03/26/14注册
322 声望
创作了3篇指南
团队
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G6
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 48
总计 847
