跳转到主内容
Siemens A56 LCD Display Replacement
你所需要的
  1. Siemens A56 LCD Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 LCD Display Replacement: 步骤 2 中的图像 1,1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 LCD Display Replacement, Front Plate: 步骤 3 中的图像 1,3 Siemens A56 LCD Display Replacement, Front Plate: 步骤 3 中的图像 2,3 Siemens A56 LCD Display Replacement, Front Plate: 步骤 3 中的图像 3,3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  4. Siemens A56 LCD Display Replacement, Back Plastic Cover: 步骤 4 中的图像 1,3 Siemens A56 LCD Display Replacement, Back Plastic Cover: 步骤 4 中的图像 2,3 Siemens A56 LCD Display Replacement, Back Plastic Cover: 步骤 4 中的图像 3,3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  5. Siemens A56 LCD Display Replacement: 步骤 5 中的图像 1,3 Siemens A56 LCD Display Replacement: 步骤 5 中的图像 2,3 Siemens A56 LCD Display Replacement: 步骤 5 中的图像 3,3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  6. Siemens A56 LCD Display Replacement, Motherboard Metal Frame: 步骤 6 中的图像 1,3 Siemens A56 LCD Display Replacement, Motherboard Metal Frame: 步骤 6 中的图像 2,3 Siemens A56 LCD Display Replacement, Motherboard Metal Frame: 步骤 6 中的图像 3,3
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
  7. Siemens A56 LCD Display Replacement, Motherboard from Keypad Interface: 步骤 7 中的图像 1,3 Siemens A56 LCD Display Replacement, Motherboard from Keypad Interface: 步骤 7 中的图像 2,3 Siemens A56 LCD Display Replacement, Motherboard from Keypad Interface: 步骤 7 中的图像 3,3
    • Insert the fine-tipped spudger in between the motherboard and the keypad interface.
    • Gently work the spudger across the length of the motherboard.
    • An adhesive exists between the motherboard and the keypad interface.
    • Once loosened, the motherboard should easily separate from the keypad interface.
  8. Siemens A56 LCD Display Replacement, LCD Display: 步骤 8 中的图像 1,3 Siemens A56 LCD Display Replacement, LCD Display: 步骤 8 中的图像 2,3 Siemens A56 LCD Display Replacement, LCD Display: 步骤 8 中的图像 3,3
    • Locate the LCD Display.
    • Above the display, there are two metal clasps. Bend the clasps until they are straight.
  9. Siemens A56 LCD Display Replacement: 步骤 9 中的图像 1,3 Siemens A56 LCD Display Replacement: 步骤 9 中的图像 2,3 Siemens A56 LCD Display Replacement: 步骤 9 中的图像 3,3
    • On the sides of the display there are two more metal clasps.
    • Gently bend the clasp so that the metal display frame becomes loose from the screen.
    • Flip the device over and gently bend the other clasp so that the metal display frame becomes loose from the screen.
  10. Siemens A56 LCD Display Replacement: 步骤 10 中的图像 1,3 Siemens A56 LCD Display Replacement: 步骤 10 中的图像 2,3 Siemens A56 LCD Display Replacement: 步骤 10 中的图像 3,3
    • Place the device so the display screen is facing up.
    • On the bottom of the display frame, locate two plastic rivets.
    • Remove these rivets by scraping with the plastic opening tool or a fingernail.
    • Once removed, the plastic rivets can only be reapplied with a heat gun.
  11. Siemens A56 LCD Display Replacement: 步骤 11 中的图像 1,3 Siemens A56 LCD Display Replacement: 步骤 11 中的图像 2,3 Siemens A56 LCD Display Replacement: 步骤 11 中的图像 3,3
    • To remove the metal frame, gently grab the frame and lift from the keypad interface.
    • If the frame cannot be easily removed. ensure that the metal clasps from steps 8 and 9 have been sufficiently bent to allow removal.
  12. Siemens A56 LCD Display Replacement: 步骤 12 中的图像 1,3 Siemens A56 LCD Display Replacement: 步骤 12 中的图像 2,3 Siemens A56 LCD Display Replacement: 步骤 12 中的图像 3,3
    • Once the metal frame is removed, the LCD display should fall from the keypad interface when tilted.
结论
Joseph Casey
于03/26/14注册
414 声望
创作了4篇指南
团队
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G6
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 28
总计 891
