跳转到主内容
加入维修社区 - 创建账户
Sidekick II Outer Casing Replacement
你所需要的
  1. Sidekick II Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Outer Casing Replacement: 步骤 2 中的图像 1,2 Sidekick II Outer Casing Replacement: 步骤 2 中的图像 2,2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Outer Casing Replacement: 步骤 3 中的图像 1,1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Outer Casing Replacement: 步骤 4 中的图像 1,1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Outer Casing Replacement: 步骤 5 中的图像 1,1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
终点
michael albaum
于01/20/10注册
87 声望
创作了6篇指南
团队
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G19
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 2,600
