跳转到主内容
加入维修社区 - 创建账户
Side Removal
你所需要的
  1. Side Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 1 中的图像 1,1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Side Removal: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Side Removal: 步骤 3 中的图像 1,3 Side Removal: 步骤 3 中的图像 2,3 Side Removal: 步骤 3 中的图像 3,3
    • Grab the top shell of the mouse and lift up to remove.
  4. Side Removal: 步骤 4 中的图像 1,1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Side Removal: 步骤 5 中的图像 1,2 Side Removal: 步骤 5 中的图像 2,2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Side Removal, Side Panels: 步骤 6 中的图像 1,2 Side Removal, Side Panels: 步骤 6 中的图像 2,2
    • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
  7. Side Removal: 步骤 7 中的图像 1,2 Side Removal: 步骤 7 中的图像 2,2
    • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
  8. Side Removal: 步骤 8 中的图像 1,3 Side Removal: 步骤 8 中的图像 2,3 Side Removal: 步骤 8 中的图像 3,3
    • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
  9. Side Removal: 步骤 9 中的图像 1,2 Side Removal: 步骤 9 中的图像 2,2
    • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
结论
另外一个人完成了本指南。
royceeklund
于01/18/13注册
115 声望
创作了3篇指南
团队
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G36
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 1,982
