跳转到主内容
加入维修社区 - 创建账户
Side Panel Removal
你所需要的
  1. Side Panel Removal, Side Panel Removal: 步骤 1 中的图像 1,3 Side Panel Removal, Side Panel Removal: 步骤 1 中的图像 2,3 Side Panel Removal, Side Panel Removal: 步骤 1 中的图像 3,3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. Side Panel Removal: 步骤 2 中的图像 1,3 Side Panel Removal: 步骤 2 中的图像 2,3 Side Panel Removal: 步骤 2 中的图像 3,3
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
结论
6等其他人完成本指南。
Oli
于01/03/14注册
1,523 声望
创作了4篇指南
1指南评论
I took it out, but now it’s not going all the way in
Ali - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 52
过去 30 天: 91
总计 3,260
